Sponsored by: CARiD
04 Discovery II Died randomly, then started back up
Old May 28, 2014 | 01:23 AM
Bart Mills's Avatar
6th Gear
Default 04 Discovery II Died randomly, then started back up
Hello,
First time posting, but hoping I could get some insight on a issues that came up today with my 04' Discovery. It randomly died while driving home today, the service engine light came on along with the oil light, and battery light. I was able to coast out of the way traffic. I tried to start it again and it would just crank and not turn over. I let it sit for 5 min and than it fired right back up and the warning lights were off I was able to drive it home with no problem. Any thoughts? Thanks in advance.
-Bart
Old May 28, 2014 | 05:21 AM
acamato's Avatar
Sounds like a crankshaft position sensor.
Old May 28, 2014 | 10:07 AM
js8488's Avatar
It does sound like it may be the crankshaft position sensor coming loose. Not really sure on all the lights coming on though...
Old May 28, 2014 | 03:53 PM
acamato's Avatar
The lights came on because it stalled.
Old May 28, 2014 | 04:27 PM
Bart Mills's Avatar
6th Gear
Thank you all for your help, much appreciated.
-Bart
Old May 29, 2014 | 05:35 PM
Bart Mills's Avatar
6th Gear
Does anyone know if heat causes the sensor to malfunction? It has stalled on me twice, but both times it was fairly hot outside. Thanks again.
-Bart
Old Jun 2, 2014 | 02:02 PM
js8488's Avatar
Is that the only time that's happened?? while it was hot outside? it could be a heat sensitive malfunction.
tsuyoi
Sep 22, 2020 10:37 AM
Gmacfilm
Dec 4, 2014 02:38 PM
EricTyrrell
Dec 4, 2011 10:23 AM
