Sponsored by: CARiD
'04 Discovery Running Rough, Using Gas Big Time
Old Jun 15, 2008 | 07:33 AM
gfeehan's Avatar
Default '04 Discovery Running Rough, Using Gas Big Time
This is my first ever post at any forum period, so forgive my lack of "posting skills."
My '04 Disco, fresh out of warranty is suddenly running rough and using vast amounts of gas, and I mean vast just to go short distances.
Not a great series of events with gas being $4 a gallon.
I ran some gasoline conditioner thru it (thinking injectors might be clogged) and no change.
Any ideas out there?
glenn
Old Jun 15, 2008 | 07:52 AM
Default RE: '04 Discovery Running Rough, Using Gas Big Time
How many miles on it, do you have a check engine light on if so what are the codes?
When was it last tuned?
Old Jun 15, 2008 | 03:38 PM
gfeehan's Avatar
thanks Mike
umm,
it has done 53k.
by the look of the maintenance schedule there has been no tuning yet.
Yes check engine light is on - concincidentally with the rough idle/running and huge consumption of gas (maybe 8 mpg)
I have no codes, I need to purchase a code reader/scanner, do you have any suggestions as to make an model.
glenn
Old Jun 16, 2008 | 08:35 AM
If your check engine light is on, you have codes, go to your local auto parts store and have them test it for free and get back to us with the 4 digit fault code numbers.
Old Jun 16, 2008 | 09:17 AM
gfeehan's Avatar
will do - I'll be back asap.
Really appreicate your guidance Mike.
glenn
Old Jun 16, 2008 | 05:36 PM
gfeehan's Avatar
Mike
codes read as follows
300 general engine misfire
306 misfire on cylinder 6
301 misfire on cylinder 1
many thanks again
glenn
Old Jun 17, 2008 | 06:06 PM
gfeehan's Avatar
Hey Mike - let me know your thoughts on the codes if you can.
many thanks
glenn
Old Aug 23, 2008 | 02:43 PM
gfeehan's Avatar
Hey Mike
I have replaced the plug wires, the coil packs and the plugs and still have a misfire on 2.
Could it be the injector?
many thanks
glenn
dillhole
Feb 20, 2020 02:30 PM
Jared9220
Oct 29, 2012 09:27 PM
Sean Price
Dec 22, 2007 02:12 PM
bdud98disco
Jul 11, 2007 08:02 PM
mge_1
May 6, 2006 07:46 PM
