Sponsored by: CARiD
04 RR / lights, turn signals, radio went out....
Old Feb 17, 2009 | 01:36 PM
marco frank's Avatar
Cool 04 RR / lights, turn signals, radio went out....
Hey All,
I have an 04 Range Rover. The turn signals, lights, and radio stopped working. I checked all the fuses in the glove box and they were fine. About a day before this happened the air suspension ( raise & lower buttons went out ) went out.
Is there another fuse panel or something that I should check?
Does anyone out there have any input on the matter ?
Thanks, Your input is greatly appreciated !!
Old Feb 17, 2009 | 08:29 PM
roverguy7's Avatar
it sounds like the light check module... get it checked out, not much you can do yourslef with this one
Old Feb 18, 2009 | 12:51 AM
Thumbs up thnx
thanx for the input ! was hoping i could handle it myself. the lights actually work / i was confused. the radio doesn't work along with the turn signals....
thanks again.
Old Feb 18, 2009 | 08:07 PM
roverguy7's Avatar
i understand, it sounds like something is bringing down the k-bus in the car, which could be several things really, bad module, corrosion, but the one i see the most is the light check module, which doesnt actually control the head lights at all... but it could be something as simple as a bad relay. either way, someone with a good knowlage of these cars and their electrical systems should take a look at it.
me 2
Nov 3, 2012 03:22 PM
gatorgrizz27
Aug 2, 2011 04:11 PM
bothomasmusic
Apr 5, 2011 06:36 PM
ROVERPIG
Nov 16, 2010 11:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
