Sponsored by: CARiD
1994 Discovery Stalling alot
Old Dec 10, 2007 | 07:37 AM
Rover5150's Avatar
Default 1994 Discovery Stalling alot
1994 Discovery with 158000 on the Odometer.
Have changed Air Filter, Water Pump, Thermostat,
Cleaned PVC, Stepper Motor, TPS, and MAF
Truck would idle rough when warm now
it stalls at red lights and has even cut off on the highway a few times.
Only codes were 45 (O2 sensor right bank)
and Code 19 ..........I also got a check engine light yesterday.
I was able to reset the codes and the lights and it ran better
but it is still stalling when warmed up
HELP!
Also noticed the coolant temp was bouncy yesterday and it started to overheat a little.
IS IT POSESSED?
Old Dec 11, 2007 | 12:51 PM
dcox's Avatar
Default RE: 1994 Discovery Stalling alot
Does it start right up after it stalls or do you have to let it sit for a while before it will start up again? Have you cleaned the throttle body and reset base idle? You may have 2 seperate issues here.
Old Dec 11, 2007 | 07:35 PM
Rover5150's Avatar
The truck starts right up after it stalls..... But it got so bad this weekend that I would make it 1000 yards and it would sputter out again. But this was after I was driving most of the day in it From Ft. Lauderdale to Boca and Back roughly 45 min each way at 70mph. On the way back it started the stalling.
I have cleaned the Throttle Body Butterfly with Cleaner.... But I have not reset base idle...
I cleaned the IAC or stepper motor but only by unscrewing it from the housing and not taking the housing off the back of the Motor (The IAC seemed clean itself).
Also I have read I am supposed to unplug it or something to reset it (Never did that with it running) maybe this is what caused this?
This really has me guessing. Last night I drove around locally maybe 5 miles then park then 20 minutes come back out and another5 miles etc. and it did not even sputter once (Go Figure)
I am pretty much a Noob with Rovers... My first and I love it and am willing to work hard but need guidance
I really appreciate the help "D" it sounds like you really know what you are doing already.
Any more ideas on what next?
Old Dec 12, 2007 | 09:11 AM
dcox's Avatar
I think you need to start with finding out what you are losing first. You are either losing fuel or spark. Get a fuel pressure gauge and hook it up then tape it to the windshield and see if pressure drops when it dies. If it drops then you need to see if you are losing voltage or ground at the pump. If pressure drops and voltage and ground are good, your fuel pump is bad. Fuel pumps tend to fail when hot.
Old Dec 12, 2007 | 07:33 PM
Rover5150's Avatar
Today I rolled the dice and drove it to work..... It made it stalling out only once ata red light
Then for the rest of the day no stalls!!!... I put more gas in tonight and everything seems a bit better.... The idle bounced maybe three times all day much better.
Perhaps I got a bad load of gas?... I also in Saturday when I put gas in I used Injector Cleaner STP in the gas tank...perhaps a bad idea?....
This weekend I think I will attemptto change out the fuel filter and test pressure and then report back then we can begin to eliminate the gremlins.
Temperature was a little cooler today though by about 15 degrees in S FLA.....
So who knows..... I am not giving up I will somehow rid the truck of the gremlins.
Here is my new invented saying:
OWNING A LAND ROVER IS ALOT LIKE BEING IN VEGAS..... YOU KEEP THINKING IT WILL TURN AROUND BUT THE CHIPS ARE DOWN AND THE HOUSE (Rover Gods) Always have an edge.
LOVE MY TRUCK!!!! I will report back and thanks D
Old Dec 13, 2007 | 08:18 AM
dcox's Avatar
We have a saying that all rovers are flex fuel, they are powered by gas or a tow truck.
Old Dec 17, 2007 | 02:18 PM
sideburns's Avatar
check fuel pressure,also distibutors may be bad,I've seen a few fuel injector rails get clogged and injectors sticking,also make sure you have a good battery,saw a series 1 that had a bad cell in the battery and the car ran like sh$t
VikingDiesel
Apr 27, 2008 02:45 PM
Rover5150
Dec 10, 2007 07:55 PM
Rover5150
Nov 28, 2007 09:57 AM
Rover5150
Nov 26, 2007 06:09 PM
DiscoveyII Driver
May 21, 2007 03:17 PM
