Sponsored by: CARiD
1995 disco fluids??????
Old Sep 18, 2010 | 08:09 PM
kcirtap's Avatar
Default 1995 disco fluids??????
how many quarts oil for oil change? what type of oil is best and what weight is beast?
how many quarts of fluid for transmission after filter change? what type of fluid is best?
what type of fluid for transfer box and how much is needed?
what is best brake fluid?
what is best fluid for power steeering?
thanks
Old Sep 19, 2010 | 07:31 PM
6 qts for the engine, Shell Rotella 15w-40.
After trans filter change have 8 qts on hand, I use Castrol Multi Vehicle ATF.
For both diffs and t-case you will need 7 qts, 85w-140.
Brake fluid is DOT3, 2 qts.
Power steering on a DI takes ATF, same as the transmission, Dexron III.
Old Sep 20, 2010 | 05:02 AM
antichrist's Avatar
google "RAVE + green oval" and download the Rave_03 CD image.
It has the owners manual (which answers all of your questions) plus other manuals like the Factory workshop manual.
dgm
Aug 17, 2012 08:06 PM
Extremity
Mar 29, 2012 10:26 AM
werldcup
Feb 7, 2008 04:15 PM
D2 2003
Mar 16, 2007 11:31 AM
wildhorses
Oct 16, 2005 10:36 PM
