Tools needed to change driveline fluids?
Old Mar 15, 2007 | 11:21 AM
D2 2003's Avatar
Default Tools needed to change driveline fluids?
Hey guys (and gals) the time has come to get ready to change transfer case, transmission and differential fluids (2003 D2).
Poking around under the truck I think I recall that a couple of the plugs take a square head grub screw type of wrench. Anyone know if a standard rachet extension will fit properly in the square recess or is there a specific tool I need to get ahold of?
Thanks for the help,
-Keith
Old Mar 15, 2007 | 12:15 PM
Default RE: Tools needed to change driveline fluids?
For the diffs and the t/case just use the end from your 1/2 ratchet wrench.
Fot the tranny an allen wrench and or open end wrench.
Are you changing the tranny filter, do you know how to service the tranny?
Make sure you use an 80/90W synthetic gear oil for the diffs and t/case, a total of 7 qts.
For the tranny 6 qts of Dextron and add a bottle of Lucas tranny additive if you want a happier tranny.
How about the other fluids, brakes, coolant and power steering, have you already done them?
Mike
Old Mar 16, 2007 | 08:55 AM
D2 2003's Avatar
Mike, thanks, as always, for the timely info.
Will be replacing the tranny filter when doing the tranny. I will be emptying the pan before I drop it though.
Thanks for the recomendation on the synthetic gear lube. I was wondering if I should give the syntheticsa try. I used synthetic grease for the first time when lubing the prop shafts. New fangled pink stuff (Mobil 1) but it does make it easier to see the fresh grease squeezing out of the u joints. I will be replacing the u joints and ball seal as soon as I get this other stuff done.
I did the brake fluidbut forgot about the power steering and the coolant. Have to add that to the list. I have a little over 51k on the truck now. I figure a little at a time and I'll get all the 60k service done by 60k.
Old Mar 16, 2007 | 11:31 AM
Your truck came with synthetic gear oil from the factory.
Shout if you have any more questions.
Mike
collin Barrows
Aug 28, 2011 07:13 AM
Bryan H
Jul 6, 2010 05:04 PM
landRoverNewbie
Oct 13, 2009 11:39 AM
m1964
LR2
Jun 15, 2008 10:06 PM
billinohio
May 19, 2007 06:18 PM
