Sponsored by: CARiD
1996 Range 4.0 brake failure!!! HELP!!!
Old Aug 7, 2007 | 05:41 PM
oliveoil's Avatar
8th Gear
Default 1996 Range 4.0 brake failure!!! HELP!!!
Today the brakes on my 96' Range completely failed...thank God I was close to home. I notice that the pedal goes all the way down as if its hitting something and I hear a clicking noise under the shifter when the brake is pressed. What could this be? I've already heard...master brake cylinder and brake booster. Has anyone else had this happen, and if so what was the fix? Thanks alot!
Old Aug 7, 2007 | 06:54 PM
Default RE: 1996 Range 4.0 brake failure!!! HELP!!!
You need to have some one check the truck. How high is your brake fluid level, when was it last changed?
Normally when the pedal goes to the floor, the master cylinder has bypassed and failed.
Mike
Old Aug 8, 2007 | 12:21 AM
johanzel's Avatar
3rd Gear
having the same prob can anyone give some adviceon what the likely prob is. pedal to the ground,fluid full, pump running continueously
Old Aug 8, 2007 | 04:15 PM
ORIGINAL: johanzel
What year and model is your truck, when was the brake system flushed last?
Mike
Old Aug 8, 2007 | 06:34 PM
johanzel's Avatar
3rd Gear
1997 range rover 4.6 hse dont know when last been flushed just bought a few months ago. will appreciate any help
Old Aug 8, 2007 | 07:20 PM
You could have air in the lines and a full flush might help but most likely either the master cylinder has failed and or the brake accumulator. Should let an experienced Rover shop take a look at it, this is not a common brake system.
Mike
Old Aug 8, 2007 | 08:01 PM
johanzel's Avatar
3rd Gear
does anyone have repair kit for master cylinder or is there any way tocheck if the accumalator is bad
Old Aug 22, 2007 | 02:15 PM
sideburns's Avatar
needs an acumulator assy and flush/bleed the system also replace the abs pump relay
Wayne
Oct 2, 2020 12:10 PM
Marni
May 29, 2014 11:13 AM
SurfRat
Sep 29, 2008 07:44 PM
skrams
Jan 21, 2007 02:13 AM
95 classic lwb
May 24, 2006 09:45 PM
