Sponsored by: CARiD
1998 Disco Audio System
Old Jan 15, 2019 | 07:27 PM
stevevjohnson's Avatar
4th Gear
Default 1998 Disco Audio System
Hello All.
I am new to the Disco family and excited. I have a problem with my stereo, I only get a faint sound from my back subwoofer. When I purchased the vehicle I had to enter the Radio code due to a new battery, after entering the code the radio comes on no problem. Just only getting a very low volume from the back, nothing out of the other speakers. Thank you.
Steven
Old Jan 15, 2019 | 09:01 PM
discorona's Avatar
Default Audio problems
I would check all the connections at the speakers first and the plug on the back of the radio.
Old Jan 16, 2019 | 07:46 AM
stillruns's Avatar
The backsoor subs are probably dry rotted by now. Take the speaker cover off and have a look.
Old Jan 16, 2019 | 11:20 AM
4th Gear
would this affect the other speakers ?
Old Jan 16, 2019 | 11:50 AM
stillruns's Avatar
They may all be rotted. Or some. These were cheap to begin with and after 20 years the rubber and paper rot. Easy to replace with some more cheap, but better made speakers. I believe they are 4 inch if memory serves me correctly.
Old Jan 16, 2019 | 02:23 PM
WaltNYC's Avatar
4" for the speakers on either side of the rear door. 6 1/2" x 2 on the subs.
I'm unclear as to what is or is not happening in your truck other than understanding that the subs don't work. This part is confusing to me...
'back' and 'other' aren't clear enough for me to understand.
Maybe start by telling us which speakers DO function?
Front tweeter by the windshield?
Front speakers on the front doors?
Rear speakers next to the cargo door?
Subwoofers? no
These audio systems are easy to work on if they have not been chopped up by previous owners.
Old Jan 16, 2019 | 07:26 PM
4th Gear
The only sound I get is very faint out of the subwoofer. All other speakers produce zero sound. Headset/Radio turns on. Sorry if the original was confusing.
Old Jan 17, 2019 | 07:43 AM
WaltNYC's Avatar
Subs have their own (very weak) amplifier. If all other speakers produce absolutely no sound I'd look first at the main amp in the passenger kick panel. First thing to do is check fuses, in particular F3 (main), F12 & F13 (main), and F4 (sat 2...bottom row). There is also a relay behind the glove box (K187).
Old Jan 17, 2019 | 12:51 PM
4th Gear
I Checked the fuses, all good. I checked behind the kick panel, AMP fuse good and unplugged and plugged the relay (seems to be in good shape. Took apart subwoofer, definitely needs to be replaced but shouldn't be affecting the other speakers. No solution yet. Could it be the head unit/Radio it self?
Old Jan 18, 2019 | 08:52 AM
WaltNYC's Avatar
If you are getting sound from the subs that suggests audio signal IS flowing from the head unit to the amp. Even the sub audio goes through the amp first. Perhaps the amp is simply blown.
Unless you need a 'night club on wheels' I'd suggest a 4 way x 40 watt amp to drive the four speakers and tweeters and then add a 250 watt mono amp dedicated to the subs. The amp for the subs makes all the difference. I use the stock amp and it sound great with the low end amped correctly. I put the sub amp in the pocket on the rear door and upgraded the woofers.
If you don't already have it, grab the electrical troubleshooting manual from the link in my signature.
