Sponsored by: CARiD
1998 Land Rover Discovery LE (trouble around 45mph)
Old Mar 4, 2008 | 08:09 PM
herblatham's Avatar
Default 1998 Land Rover Discovery LE (trouble around 45mph)
I just bought a 1998 Land Rover Discovery LE and when Im around 45mph and accelerating, the car stops accelerating, rpm drops then goes back up and I'm able to speed up again. Any ideas on what's going on, and how to fix it?
Old Mar 5, 2008 | 11:51 AM
WolfPack's Avatar
Default RE: 1998 Land Rover Discovery LE (trouble around 45mph)
Fuel issue most likely. Or air supply. Check the air filter first (easiest), then move to the fuel system. When was the last time you changed the fuel filter? Also could be some bad gas..lots of trouble spots in the fuel system. If it's driveable for you, try a can of Iso-Heet or fuel system cleaner, might help a bit.
It might also be the transmission/torque converter. Any noticable slippage anywhere else in the rpm range? Also is the loss of power ALWAYS at 45 mph, or is it at a specific RPM range in a certain gear or what?
Sorry for listing so many causes...but a little disambiguation never hurt
Old Mar 5, 2008 | 12:40 PM
herblatham's Avatar
It's always at 45-50 mph, Doesn't slip anywhere else.
me6067
Feb 15, 2015 08:25 PM
Gimebakmybulits
Jul 13, 2014 07:57 PM
er1c
Oct 10, 2013 01:20 PM
kerbse
Sep 23, 2007 01:23 PM
norcalfrank
Aug 10, 2007 01:33 PM
