Sponsored by: CARiD
1999 Disco SD no start
Old May 9, 2017 | 02:58 PM
wadouglas's Avatar
7th Gear
Default 1999 Disco SD no start
I have a Disco SD. It has a new fuel pump, new CPS sensor, new fuel pump relay, new fusible links, and does not start. Only way it starts is with starting fluid. It doesn't stay running. I am at a loss of what it could be. Turns over fine and has spark at all plugs. The motor was recently resealed/rebuilt; less than 46 miles ago. I am at a loss, any help?
Old May 10, 2017 | 08:31 AM
WaltNYC's Avatar
What is the fuel pressure at the fuel rail? Should be ~35 PSI. Also, better to post this in the D1 section where you will get more eyes on it.
Old May 10, 2017 | 03:30 PM
wadouglas's Avatar
7th Gear
Default Fuel Pressure
It is less than 35PSI. I am wondering if the battery is just not strong enough to have a continuous flow at 35PSI during start.
Old May 17, 2017 | 09:43 AM
wadouglas's Avatar
7th Gear
Issue is resolved. I have a bad alternator and the battery did not have enough amps to crank the motor and power the fuel system/ECU. What I found was that all the connections had power, except where the fuel pump was concerned. When the key was turned to position to 2, the fuel pump sent modest amount of fuel to the rail, but not enough to fire the motor. I had spark, power to all other componets, but nothing at to the fuel system. I had my battery charged and tested at a local auto parts store. When I hooked it back up, the vehicle started right up. I'm taking the alternator in to be rebuilt and will hopefully continue to enjoy this vehicle and begin the build out. Thanks for all the input.
tofargone
Oct 14, 2014 08:10 AM
cu42dk
Apr 4, 2014 06:36 PM
whitehat
Oct 29, 2012 02:13 PM
58ford
Jul 13, 2011 06:07 AM
armyeng
Mar 8, 2011 05:58 PM
