Sponsored by: CARiD
1999 land rover discovery II camshaft position sensor
Old May 8, 2007 | 05:38 PM
icoolyou's Avatar
5th Gear
Default 1999 land rover discovery II camshaft position sensor
I took my 1999 discovery II to a well know mechanic shop, they scanned it with an OBD II and said the CAMSHAFT POSITION SENSOR needed to be replaced, but they could find it. They said information online said it was by the #1 cylinder, and it took 1/2 an hour to replace. Does anyone know where the camshaft position sensor is located?
Old May 8, 2007 | 07:57 PM
okdiscoguy's Avatar
Default RE: 1999 land rover discovery II camshaft position sensor
not positive if yours is the same, but mine is behind the #7 cylinder.
Old May 23, 2007 | 08:52 AM
STOMPER's Avatar
8th Gear
THE SENSOR BEHIND No7 CYL IS THE CRANK SHAFT SENSOR...
THE CAM SENSOR IS LOCATED AT THE FRONT OF THE MOTOR JUST BELOW THE WATER PUMP..ON THE RIGHT HAND SIDE LOOKING AT THE ENGINE...
couzteau
Aug 2, 2024 08:06 AM
airisgood01
Mar 17, 2020 07:02 AM
DeepBlueWater
Nov 22, 2019 07:51 PM
Lee97Disco1
Feb 7, 2011 10:06 PM
icoolyou
May 16, 2007 05:50 PM
