Sponsored by: CARiD
1999 TD5 series 2
Old Nov 18, 2016 | 11:14 AM
Pappion's Avatar
Default 1999 TD5 series 2
Hi my
td5 will not start, the problem started when on the motorway approaching a hill power just disappeared accelerator did nothing and engine stopped would not start.
Since this happened I have tried various things, replaced crankshaft sensor. Checked fuel pump and filter cleaned contacts on sensors. Replaced injector sealing o rings
And washers. It has started a few times but faded after a minute, when it does start black smoke comes out the exaust.
Any ideas?
Old Nov 25, 2016 | 04:59 PM
loanrangie's Avatar
Have you check the injector harness for oil at the ECU plug ?
You are better off on a UK/AUS forum as the US didnt get any diesel Landy's.
Old Dec 1, 2016 | 03:38 PM
OffroadFrance's Avatar
Originally Posted by Pappion
Hi my
Any ideas?
How long is a pice of string! ............... it's difficult to know what is wrong without seeing and testing the truck and engine. It may well be the fuel pressure regulator, the turbo actuator, the injector harness leaking oil into the ECU, in fact many things. The early TD5's had an issue with the oil pump bolt loosening and dropping out. I doubt if it is that though. Black smoke usually means incomplete or bad combustion of diesel fuel.
This may help your analysis.
https://www.google.fr/search?q=readi...hrome&ie=UTF-8
pgaukroger
Feb 29, 2016 05:56 AM
Mark Crawford-Thomson
Defender
Oct 11, 2013 07:56 AM
timcolebrooke
May 27, 2007 03:04 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
messias
Oct 5, 2005 02:28 PM
