Sponsored by: CARiD
2000 landrover discovery
Old Nov 24, 2008 | 03:14 PM
nicoleandmorgan's Avatar
Default 2000 landrover discovery
I just took my landrover in for flashing engine light it would flash and go down to 10 mph then once it stop flashing it would run fine . So the mechanic put it 2 new ot sensors a new batterty a coolant sensor plugs wires new air filter. Well I got it back sat the check engine light flashed for 2 seconds then stopped my husband informed me that I should go get the computer resethe is in iraq so there only so much he can do.I did that today again I drove it down the road it flashed for 2 seconds the only differnence this time around it does not go dow to 10 mph any suggestions I have to call the mechanic back tommrow and let him no it's still not running properly I am just getting mega frustured it was in the shop for a week
Old Nov 27, 2008 | 02:54 PM
Rich 00 DISCO's Avatar
Default RE: 2000 landrover discovery
you need someone with LR experience - computer codes should have been read - sounds as if your mechanic is just hunting for possibles and likely has replaced things that needed replacement sooner or later. However, the codes allow an experienced tech to isolate the problem and fix it quickly and as cheaply as possible. Ask the forumfor a referral in your local area (it's likely someone on the board will be able to put you in the right direction) Good luck and thanks for your sacrifice.
Old Nov 28, 2008 | 07:24 AM
So much for that mechanic.
Go get the codes read and get back to us with the 4 digit fault codes numbers. Many auto parts stores will do this for free.
arrjay360
May 30, 2014 07:55 PM
cadetgrl24
Feb 15, 2012 09:07 AM
tazangel2007
Nov 7, 2010 04:05 PM
superdejison
Feb 1, 2010 05:13 PM
DesertRoverGuy
Jun 2, 2008 08:51 PM
