Sponsored by: CARiD
2001 Disco - Automatic Transmission oil change help
Old Oct 2, 2005 | 07:31 PM
imag's Avatar
Default 2001 Disco - Automatic Transmission oil change help
I have changed my 2001 Disco SE7's automatic transmission oil (with Dexron III), but I am not certain if I managed to get enough back into the system. I managed to get 4 quarts (US) and 600ml into the transmission.
Question to the folks that have done this before: Is that enough ?
My procedure was:
1. Drain oil through the drain plug.
2. Open filler plug (8mm allen key) at front side of auto tranmission sump.
3. Managed to add 2 quarts without problems - started "overfilling" then.
4. Started the engine, idling along (gear selection in P), managed to add more ATF.
5. With brake pressed, ran through the gear selection, P-R-N-D-3-2-1 and back a few times (wife, the helper did that), while I managed to get more in through the filler plug until the fluid came out of the filler hole.
6. Close the filler plug.
Steps 4 and 5 were done twice.
Any replies are much appreciated.
Old Oct 4, 2005 | 12:17 AM
redmond's Avatar
4wd High
Default RE: 2001 Disco - Automatic Transmission oil change help
that should take around 5 quarts remember that the converter and cooler lines will also hold fluid that will not drain the best thing is a pf5 flush which will replace all 15 quarts you can go to a dealer or a service center
Rover Newbie
Jun 25, 2015 07:03 AM
megathunder
Sep 26, 2014 09:36 AM
collin Barrows
Aug 28, 2011 07:13 AM
mtfife
May 4, 2011 07:32 AM
1porsche
Oct 5, 2008 06:32 PM
