Sponsored by: CARiD
2001 Discovery 2 SE help, 3 questions
Old Aug 21, 2014 | 09:47 AM
Malcohmh's Avatar
6th Gear
Default 2001 Discovery 2 SE help, 3 questions
1) So every time I turn my 'left' turn signal, all my interior lights: in the radio, ac screen, and dash lights, all start flashing/ dimming like the blinker is taking power from it. Then I use my 'right' turn signal and it works just fine, no weird flashing/ dimming? I know that's not normal.
2) The 'mode' button under the gear shifter? Is that a sport mode?
3) There's the standard looking gear shifter above the regular shifter. Does that put the truck in 4wd? Or is it always in 4wd?
Thanks for the help.
Old Aug 21, 2014 | 12:15 PM
drowssap's Avatar
2. yes that is sport mode
3. that is for your transfer case, to shift from 4 high to 4 low, it is always in 4 wheel
Old Aug 21, 2014 | 01:18 PM
Malcohmh's Avatar
6th Gear
Default Reply to question
Alright, that's what I thought about the mode button. For the high and low mode, I leave it where it is on high for driving normally and driving in snow/ice? The AWD is maybe why it has terrible gas mileage, plus v8 engine? haha
Thanks for the reply
Old Aug 21, 2014 | 03:21 PM
roverpdx's Avatar
Default bad ground?
1. probably a bad shared ground for the turn and other accessories that are flashing. most likely front left signal ground could be traced to faulty ground bolt
Old Aug 21, 2014 | 04:07 PM
roverpdx's Avatar
Default bad ground?
1. probably a bad shared ground for the turn and other accessories that are flashing. most likely front left signal ground could be traced to faulty ground bolt.
Old Aug 21, 2014 | 09:07 PM
Malcohmh's Avatar
6th Gear
Default Question
Okay, should I really be worried about that then? Will that cause my truck to break down if I don't repair that? If it isn't then I will probably put that off last, it happens every other time I drive
PanamaDisco
May 13, 2014 07:30 PM
ajbilliot
Jan 10, 2011 10:41 PM
Spencerfitch
Apr 12, 2010 04:08 PM
johnkbl
Jan 19, 2010 05:22 AM
NeelyTurner
May 31, 2007 07:25 PM
