Sponsored by: CARiD
2001 Land Rover Discovery II
Old Jun 22, 2014 | 11:15 PM
nomad722's Avatar
Default 2001 Land Rover Discovery II
Have an issue where gear shift won't go out of park and brake lights aren't working. Googled the info and was told probably the brake pin (will cause both issues if bad). Tried two pins, no joy. Was told could also be the neutral safety switch. Gear will not go into gear unless I lift the cover and push the bronze **** that temporarily unlocks, but is no assistance on brake lights . Any ideas would be appreciated. I'm not too auto literate, much less Land Rover literate so any assistance or ideas would be appreciated. Thanks...
Old Jun 23, 2014 | 10:36 AM
SDinDS's Avatar
Did you check the fuse?
Old Jun 23, 2014 | 11:12 AM
acamato's Avatar
Did you check the brake switch on the pedal?
umoms
Jan 3, 2008 08:40 AM
walkingtall
Dec 2, 2007 08:28 AM
strayjj
Jun 24, 2006 06:56 PM
DiscoGravy
Jun 21, 2006 06:52 PM
airborne0102
May 8, 2006 06:40 PM
