Sponsored by: CARiD
2002 DISCO STARTING LIKE PULLIN TEETH
Old Apr 8, 2008 | 03:25 PM
DiscoOn22s's Avatar
Default 2002 DISCO STARTING LIKE PULLIN TEETH
OK I posted about this before but never really got a straight answer or if I did I can't find the forum to read back on it. OK 2002 Disco starts like a champ in the morning or if its been sitting for over 3 or 4 hours I would say. However if I get it started and lets say drive to Walmart (about 10 minutes away or anywhere else) park it and go inside for 20 minutes; when I come back out and try to start it up it usually takes about 3 start attempts for it to start. What can it be? I have changed plugs and wires just because it was time. Bosch Plats 4. Magnecor 8mm wires. Battery is a 3 month old Optima red top. It starts in the morning so I rule out the alternator not charging thebattery. So now I turn to you guys for ideas. Mike I think you said something about a check valve in the fuel line but how do you explain the start in the mornings? I would think that is more than enough time for fuel to drain completely back to the tank if that was the case.
Old Apr 8, 2008 | 03:36 PM
Default RE: 2002 DISCO STARTING LIKE PULLIN TEETH
Have you still not thrown a code?
If not, I would lean towards a crank sensor, that won't always throw a code and can cause whqat you are describing.
Old Apr 8, 2008 | 06:50 PM
DiscoOn22s's Avatar
crank sensor... how big of a job is that? how much do they cost?
Old Apr 8, 2008 | 06:51 PM
DiscoOn22s's Avatar
by the way 2002 disco with 82200miles on it.
Old Apr 8, 2008 | 07:55 PM
landrover1502's Avatar
2002 d2 does not have a fuel return line so if fuel is your problem you probably need a pump. put a gauge on it and drive it let it sit and see where the pressure is at when u attempt to start. should be the same press as when u first started the car. around 50lbs if i remember correctly. if the pressure is ok id look at a crank sensor like mike said
Old Apr 9, 2008 | 07:27 AM
ORIGINAL: landrover1502
What do you mean, the D2's don't have a fuel line, you had better crawl under your truck and get better acquainted.
Old Apr 9, 2008 | 07:29 AM
ORIGINAL: DiscoOn22s
If it is the crank densor, they are about $80 and are located on the back side of the drivers head, held on with 2 bolts. A little hard to remove but with patience, duable.
Old Apr 9, 2008 | 12:55 PM
DiscoOn22s's Avatar
thanks guys i was wondering if there is a way to check the sensor? multimeter? voltage check?
Old Apr 9, 2008 | 03:21 PM
Yes there is and I don't remember how. It will need to be tested when it is in a no start mode.
A really good scanner will probably show the sensor activity.
Roverrocks
Jan 1, 2014 11:45 PM
jbkroh
Aug 13, 2012 02:03 PM
Kyra96Disco112
Nov 12, 2011 08:19 AM
RobK
Jun 30, 2011 08:25 PM
Viktoira
Off Topic
Feb 27, 2007 06:14 AM
