2003 Land Rover Discovery S Engine Overhaul
Just bought it with 98k. So, in the next few weeks I planned on doing most if not all know gaskets that are known to not hold up. Also, I planned on checking the front cover and replacing oil and water pump along with the timing chain and gears and front and rear crankshaft seals. Heads and valve gaskets a long with intake and bolts that come with the kit. I still debating if I should remove the engine out the bay to really clean up my engine. I have the digital rave manual.
The question I have is should I use gasket sealant on non- rubber gaskets?
