Sponsored by: CARiD
2003 Land Rover Discovery S Engine Overhaul
Old Dec 10, 2013 | 09:26 PM
roverwoody's Avatar
Default 2003 Land Rover Discovery S Engine Overhaul
Just bought it with 98k. So, in the next few weeks I planned on doing most if not all know gaskets that are known to not hold up. Also, I planned on checking the front cover and replacing oil and water pump along with the timing chain and gears and front and rear crankshaft seals. Heads and valve gaskets a long with intake and bolts that come with the kit. I still debating if I should remove the engine out the bay to really clean up my engine. I have the digital rave manual.
The question I have is should I use gasket sealant on non- rubber gaskets?
Old Dec 11, 2013 | 08:42 AM
drowssap's Avatar
black RTV on everything. "I" would look at ARP head stud kit instead of the factory STY bolts.
Old Dec 11, 2013 | 11:26 AM
roverwoody's Avatar
Thanks. One more question. Do I put Black RTV on rubber seals as well?
Old Dec 11, 2013 | 01:17 PM
drowssap's Avatar
like say valve cover gaskets? I do and have never had to tighten them
Old Dec 11, 2013 | 03:23 PM
04duxlr's Avatar
If you pull the motor you can do the rear main seal.
Old Dec 11, 2013 | 03:31 PM
roverwoody's Avatar
I thinking of pulling the engine for that exact reason to get to the rear seal. Is there a gasket or isolate between the engine and transmission?
aguison
Feb 24, 2015 01:15 PM
doogaloo
Aug 19, 2013 06:47 PM
ara25
Mar 30, 2011 03:43 PM
ShadowMerchantBC
Mar 23, 2011 08:00 PM
Bernie
Mar 5, 2009 10:45 AM
