Sponsored by: CARiD
2004 DII wiring mystery after LS swap
Old Sep 2, 2021 | 08:00 PM
BoulderCharles's Avatar
Default 2004 DII wiring mystery after LS swap
Here’s a good test of your Land Rover expertise!
I have a 2004 Discovery II that I swapped to an LS with a 6L80 (I’ll share more when it’s done and done). I have unplugged the tranmission control unit, yet the “limp mode” lights are still illuminated (Manual, Sport, and blinking D in the PRNDL). According to all electrical diagrams that I can find (including the one for 03MY), this shouldn’t be possible as the Manual/Sport lights are illuminated by the TCU.
I have the RW Engineering CANbus gateway, which communicates between the GM ECM and Land Rover systems. The traction control and HDC are also illuminated (no ABS) but I suspect these are linked to the “limp mode” issue.
Does anyone know how these lights can be illuminated? Is there a “limp mode” signal that is being sent to the BCU or IDM?
Old May 31, 2022 | 05:57 PM
Jack Burton's Avatar
I have the answer, I think, but I want to talk to you about other things and I'm not sure if you're still around.
Old Jun 2, 2022 | 08:51 AM
FYI, this was solved by setting the Rover's BCM to manual transmission mode. This works because the manual transmissions do not have a transmission computer so the Rover stops looking for one and the lights turn off. You'll need a Land Rover programming tools or a local shop with one.
toofaroffroad
Oct 28, 2022 08:02 PM
AZRover
Dec 23, 2016 02:10 AM
Trdeuso
Aug 4, 2015 05:11 AM
Greg Madden
May 12, 2015 07:00 AM
goon
Feb 26, 2011 08:01 AM
