Sponsored by: CARiD
Warning lights
Old Jul 27, 2015 | 04:35 PM
Trdeuso's Avatar
3rd Gear
Default Warning lights
Let me start by saying I really do not know much about vehicles except general maintenance. I have a 2004 discovery that the drive indicator blinks along with the mode lights T and S. If you turn it off and back on the S mode light comes on and you can push the mode selctor and the will go off. When the indicators are on however, it doesn't seem to want to pull out. But if you push the accelerator it will go and the lights continue to flash. Does anyone know if this could be a transmission issue?
Old Jul 27, 2015 | 05:20 PM
Do you even know what the S and M lights are for and how to use them?
S is for Sport mode allowing the tranny to shift faster based on your throttle pressure and only in High range. The M is to lock the tranny into a specific gear, only in low range.
Old Jul 27, 2015 | 06:11 PM
Trdeuso's Avatar
3rd Gear
Thank you Mike. I had a vague idea what the modes where, but have no idea why they come on and continue to flash unless you turn the vehicle off and restart it.
Old Jul 28, 2015 | 05:13 AM
drowssap's Avatar
the first thing you want to do is have your battery and alt. checked, if your charging system is not putting out better than 13.5 volt it will cause the blinking S&M lights. the reason the truck doesn't want to move is the tranny is in default mode which is 3rd gear only. hope this helps
Old Jul 28, 2015 | 03:06 PM
Trdeuso's Avatar
3rd Gear
That does help. Just had a new battery installed so I will get the alternater checked. Thank you drowssap
Old Aug 2, 2015 | 08:37 PM
Derrick82's Avatar
Default Bypass front drive shaft
2000 disco 2 missing front drive shaft, is there any way to override having to start in 1st gear and shift up to drive?
Old Aug 3, 2015 | 06:22 AM
Sure there is, manually engage the CDL and you can drive on the rear shaft only.
Old Aug 3, 2015 | 06:51 PM
Derrick82's Avatar
Default Cdl
How do I do that, I can't locate the shift nipple
Old Aug 3, 2015 | 07:55 PM
PM me your number and I'll call and walk you thru it tomorrow.
Old Aug 4, 2015 | 05:11 AM
drowssap's Avatar
you a search for locking CDL there should be a ton of pictures of the stud that you need to turn
cipher982
Nov 9, 2019 11:22 AM
gmutis
Jul 21, 2006 04:43 PM
ptmelendez
May 12, 2006 08:06 PM
ChrisK
Freelander
Dec 19, 2005 01:38 AM
skilley
Dec 12, 2005 09:24 PM
