Sponsored by: CARiD
2004 RR kills battery in the cold
Old Feb 19, 2014 | 06:18 AM
vinifera's Avatar
Default 2004 RR kills battery in the cold
I've replaced the battery, not the problem. The battery goes so dead that there are no interior lights and you can't turn the key. I can charge it over night and it starts. But as soon as the temperature drops, dead again.
And it losses all of its settings.
Something cold related must still be running ?? All lights are off, radio off, I hear the air suspension "empty" and it sounds totally silent. Any ideas what cold related CM cold still be active ? We've got warm weather for the next two days but then back into the deep freeze
Old Feb 19, 2014 | 09:27 PM
tuercas viejas's Avatar
Vinifera hola!
My suggestion would be to remove the battery and get it checked! Replace it if in doubt,
Also look at the ground cable it tends to corrode. When charging look for 13,5 14.2 volts
It is essential that the battery is in good condition; this car consume a lot of power even when switched off and before the systems go to sleep!
By doing what you are doing you run the risk of damaging your SatNav system as a circuit board integral battery will eventually be run down and the program lost in the BIOS. Curtains! They are about $3500 to replace.
T/V
Old Feb 27, 2014 | 05:23 PM
Range's Avatar
6th Gear
Bad alternator. It wouldn't hurt to check that also. Rusty ground wire could do it too.
bcbp
Aug 31, 2016 07:37 AM
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
starcraft
Jan 5, 2008 09:23 AM
arrkerr
Dec 14, 2005 10:06 AM
