Sponsored by: CARiD
2005 landrover freelander SE burned coil
Old 01-26-2016 | 08:31 PM
Rovrdude's Avatar
Exclamation 2005 landrover freelander SE burned coil
Can someone assist. I have a 2005 freelander and it was showing a code that 6 and 3 cylinder misfire switched out both coils and plugs car ran fine then all of a sudden 6 failed again replaced coils ran good for one day then 3 cylinder coil burned up. Replaced it again and that one burned up too, any ideas , please help.
Old 03-05-2016 | 12:15 AM
Kacykasum's Avatar
Hey I was wondering if you ever found out anything? I have similar issues! Thank you
Old 03-05-2016 | 09:22 PM
Rovrdude's Avatar
I just found out the PCM is bad , that one was switched out from prior owner because he lost the key, and he got a PCM , control module ! Cylinder and key from a totaled vehicle. But I have the original PCM , module and bought a new key from landrover with programmable chip. So I have to get that key programed to match, but I'm bieng told it can only be done at dealer. If any ideas pleas let me know
finman
03-31-2011 09:44 AM
99LRDisc
05-22-2009 09:51 PM
wilson96rr
Audio/Visual Electronics
02-16-2009 01:36 PM
Max_A6
06-28-2007 03:55 PM
VB_Rover
07-20-2005 02:43 AM
Quick Reply: 2005 landrover freelander SE burned coil
