Sponsored by: CARiD
2005 landrover freelander SE burned coil
Old Jan 26, 2016 | 08:31 PM
Rovrdude's Avatar
Exclamation 2005 landrover freelander SE burned coil
Can someone assist. I have a 2005 freelander and it was showing a code that 6 and 3 cylinder misfire switched out both coils and plugs car ran fine then all of a sudden 6 failed again replaced coils ran good for one day then 3 cylinder coil burned up. Replaced it again and that one burned up too, any ideas , please help.
Old Mar 5, 2016 | 12:15 AM
Kacykasum's Avatar
Hey I was wondering if you ever found out anything? I have similar issues! Thank you
Old Mar 5, 2016 | 09:22 PM
Rovrdude's Avatar
I just found out the PCM is bad , that one was switched out from prior owner because he lost the key, and he got a PCM , control module ! Cylinder and key from a totaled vehicle. But I have the original PCM , module and bought a new key from landrover with programmable chip. So I have to get that key programed to match, but I'm bieng told it can only be done at dealer. If any ideas pleas let me know
finman
Mar 31, 2011 09:44 AM
99LRDisc
May 22, 2009 09:51 PM
wilson96rr
Audio/Visual Electronics
Feb 16, 2009 01:36 PM
Max_A6
Jun 28, 2007 03:55 PM
VB_Rover
Jul 20, 2005 02:43 AM
