Sponsored by: CARiD
2005 LR3 suspension fault
Old Oct 22, 2016 | 01:31 PM
RigbyRover's Avatar
Default 2005 LR3 suspension fault
hey everybody, I'm having issues with my suspension.
I started getting suspension fault code.
the last 4 Saturdays i've been troubleshooting.
i bought a compressor rebuild kit on ebay. completed the rebuild and reinstalled. i had the bearing bolt for the piston come off several times until i put some blue lock tight on it.
it was running but then i started getting the vehicle raising slow code.
determined that i had air leaks on the fittings, so i ordered the metal replacement end cap from ebay also.
while waiting for the cap the piston bolt came undone again and ruined my compressor.
after rebuilding the compressor i also bought all new height sensors and installed them.
i didn't get locations for the corresponding part numbers at the time of install. i have them now and will be verifying correct install locations after i'm finished here.
my current dilemma... I just received my new compressor i bought from parstgeek.com yesterday.
installed it and the new relay that was included. still getting a suspension fault immediately after starting.
i unhooked the neg cable to reset the ecm several times. also did the hard reset... neg and pos cables removed then jumper wire for 10 min or more, reattach etc... still compressor not cycling...
any ideas?
angrylobster
Mar 30, 2016 07:59 AM
Pilot77
Dec 26, 2015 05:30 PM
06Range
May 8, 2013 09:01 PM
