Sponsored by: CARiD
2005 lr3 turning noise
Old Oct 3, 2012 | 10:38 AM
FBLR3's Avatar
5th Gear
Default 2005 lr3 turning noise
Hello!
I own a 2005 lr3 that shifts beautifully. However, when I turn in either direction from a stop the truck will make a grinding/ cavatation noise. This does not happen all of the time and only when starting to turn from a complete stop. If turning while already rolling there is never any noise.
Any thoughts on what this may be?
Old Oct 3, 2012 | 07:33 PM
Where is the noise coming from?
Inside or under the hood? Front or back?
Old Oct 3, 2012 | 09:49 PM
FBLR3's Avatar
5th Gear
Default 2005 LR3 Intermittent Turning noise
The noise (cavitation/vibration) is coming from the same side as the vehicle is turning. It is not under the hood, but rather from outside the vehicle on the turning side. The noise does not happen all of the time, and when it does, it is only when getting going from a dead stop and turning; such as when making a turn from a stop sign.
Thank you for the response and any insight or information is appreciated.
Old Oct 4, 2012 | 07:55 PM
Sounds like its the tires then, sorry but this is very hard to figure out without being there.
Rotate the tires front to back, see if the noise follows.
david4ducati
Mar 1, 2015 07:59 PM
jamiederr
Oct 31, 2010 03:00 PM
mwindth
Nov 28, 2008 08:45 PM
EASTLAND
Jul 30, 2007 05:47 PM
Prepilot_3ck
Nov 27, 2006 06:33 PM
