Creaking noise while turning...
Old Jul 28, 2007 | 01:33 PM
EASTLAND's Avatar
Default Creaking noise while turning...
97 Discovery automaticwhich has recently started making a creaking noise while turning and accelerating. If I'm parked and turning the wheel back and forth it makes no noise but say every time I pull onto the street from my driveway it's almost like awalking on a creaky floor sound is about the best wayI candescribe it. Unfortunately I'm going to have to put her in the shop just curious in the meantime if anyone has any suggestions as to what it might be. Thanks!
Old Jul 28, 2007 | 02:42 PM
2000 Disco 2 SD7's Avatar
Default RE: Creaking noise while turning...
Do you know if your body mounts or suspension bushings have been replaced? If so maybe they were replaced with early generation graphite which are known to talk to you.
Old Jul 28, 2007 | 03:39 PM
If not any of the bushings then I would suggest you may have one of your front swivels low on oil, how long since you have checked them?
Mike
Old Jul 29, 2007 | 01:50 PM
EASTLAND's Avatar
I've only owned it for a little over a year. I haven't done anything with mounts, bushings or swivels. I'll have a looksee although as far as the swivels go, where and how do I go about checking those? Thanks guys.
Old Jul 30, 2007 | 05:47 PM
Landzu's Avatar
ORIGINAL: EASTLAND
No most of the swivels have had a gray grease put in at the dealers.
Get a silicon spray and get every bushing you can or spray one side and work
to the next to find which ones it maybe, NO WD-40 as it will mess up rubber bushings.
DiscoEiner
Sep 21, 2014 02:37 PM
aguison
Apr 20, 2013 06:51 PM
TheBelly
Aug 10, 2008 04:39 PM
Mark G
Dec 4, 2007 01:01 AM
