Sponsored by: CARiD
2006 LR3 AC doesnt blow
Old Sep 5, 2013 | 10:59 AM
Deaton1076's Avatar
8th Gear
Default 2006 LR3 AC doesnt blow
I heard a gurgling noise for a couple of days then it just stopped blowing. So I took it to a local auto AC shop and he says its the blower motor and resistor. With a price tag of $700+, I got the parts myself and replaced them. Still doesn't work...
Checked my fuses and all good. I can hear the compressor kick in but nothing comes out.
Old Sep 7, 2013 | 03:38 PM
roverguy7's Avatar
What fuse did you check?
J-case fusible link under the hood #12 provides power to the blower through the relay. The resistor module controls ground, and it in turn is controlled by the HVAC head. I have had to replace all of the above at one point or another for your symptoms, aside from the HVAC head. Double check your fuse, swap your relay, make sure everything is plugged in all the way. If still nothing, the ground (through the resistor) for the blower is located behind the RF wheel liner.
Old Sep 9, 2013 | 10:49 PM
Deaton1076's Avatar
8th Gear
Seems to be the control module...
Any suggestions as to where I may find one that's reasonably priced?
Part# JFC500970
Glen11
Jul 4, 2014 04:03 PM
Gray8188
Jul 14, 2012 08:33 PM
Bean
Jul 15, 2010 11:13 AM
Eak69
Apr 4, 2010 11:52 AM
ashby1
Mar 7, 2005 12:38 PM
