Sponsored by: CARiD
2006 Range Rover Sport Door Lock
Old Jun 15, 2009 | 09:17 PM
boomer14's Avatar
Default 2006 Range Rover Sport Door Lock
Hello all,
I am a GM tech attempting to remove the driver's side door lock assembly. Got the trim panel off-no problem.
Can see no access to inside of door. I see what appears to be an access plate with 6 bolts. The window regulator is attached with two small studs with nuts. If I remove the studs and bolts the window drops as does the regulator still not giving access to the inside of the door.
I see 2 or 3 silver torx on the white plastic regulator. Do I remove them to get access plate off? I have worked on about every make and model made and this one has me stumped.
At this moment with the trim panel off I see no access to the outer driver's door handle or lock.
Please help!!!!
Rob
Deutsch100
Oct 30, 2016 01:21 PM
alti
Feb 7, 2012 09:38 AM
SuperchargedV8
Oct 27, 2011 12:19 PM
nvrsetl265
Jan 15, 2008 01:59 PM
