Sponsored by: CARiD
2008 LR3 Cooling System Bleed Cap
Old Oct 6, 2014 | 09:20 PM
seanmclaughlin64@gmail.com's Avatar
5th Gear
Default 2008 LR3 Cooling System Bleed Cap
Hi All-
I have looked all over the site and at the free shop manuals and have not seen a reference to using the bleed cap that is located under the engine cover as a third leg of a T fitting. I had my T fitting crumble and leak and ordered a replacement on British Atlantic and replaced it. It's called the Bleeding Fitting. However, none of the manuals refer to it when talking about bleeding. They only reference the main tank bleed screw and bleeding the system with the engine running by opening the reservoir cap 1/4 turn. Just curious why this other fitting is there when no one refers to it. BTW, my low coolant light is still on and it's not low on coolant. I have the 4.4L HSE.
Thanks!
Old Oct 13, 2014 | 11:47 AM
LR1LE50th's Avatar
8th Gear
The bleed valve helps prevent an air pocket in the system etc. I remove bleed valve cap and top it off with 50/50 anti-freeze with the reservoir cap off and topped. Not sure what you're looking for?
newbold13
Nov 21, 2020 02:30 PM
pilsner
Jun 5, 2012 11:24 AM
Griff Drew
Dec 30, 2011 07:26 PM
pilsner
Oct 25, 2010 05:55 PM
tbesselman
Aug 27, 2008 07:48 PM
