Sponsored by: CARiD
2008 LR3 Engine bogging down going up a hill
Old Apr 1, 2016 | 06:42 PM
boggieshoos's Avatar
Red face 2008 LR3 Engine bogging down going up a hill
The problem I having is when I am traveling a normal speed of 55 mph on a straight away. Then I must go up a steep hill. The RPMS go up but the doesn't kick down to get up the hill. It having a hard time getting up the hill. I have taken it to the dealer and no codes twice. It has a slight miss, i sometimes smell gas, and muffler is in great shape. Please help if you know what i can do.
thanks, boggieshoos
Old Apr 3, 2016 | 06:33 PM
JAIMELU's Avatar
something is wrong with your kick down systen at transmission side, check your tranny
Old Apr 5, 2016 | 12:56 AM
Charlie_V's Avatar
I wish I had an lr3. I've started watching your forums just to get an idea what to look for in one.
The component that might unify all of those problems is the throttle position sensor. It informs the transmission when you are heavy on the pedal and also informs the engine when you want more gas. If it is faulty your engine could bog by having too little or too much gas, and fail to tell the transmission that you want to go faster or maintain speed regardless of the strain on the engine.
Old Apr 6, 2016 | 01:42 PM
sleepercoupe's Avatar
Pull codes and report back.
Engine, Trans, Transfer and ABS. Check the reading while watching live data on the TPMS and that should tell you whether its reading or not.
Sounds like a trans is in order depending on mileage.
Old Apr 9, 2016 | 12:53 PM
BritishautoworksSD's Avatar
I wonder if the transmission will shift in command shift mode. In Drive position, move the shifter to the left and push it to the negative sign or the rear of the LR3. This should down shift the transmission.
If the engine is not running correctly, you can have poor shift quality due to lack of engine power. Your check engine light will most likely be on, especially if you have a misfire.
Old Apr 9, 2016 | 03:07 PM
Good call, I was rereading this and thought well if a cylinder is down (most likely coil pack or basic tuneup) it could cause the same issue. But the light would be on. It could be a pending code, I can't remember the number of times it has to misfire consecutively to set the light.
fmbchoppers
Jan 23, 2015 08:58 AM
kcabpilot
Dec 4, 2012 02:27 PM
Brian Barr
Jan 13, 2012 08:29 AM
bcolins
Jun 21, 2011 08:06 AM
elboy0712
Mar 14, 2010 10:00 PM
