Sponsored by: CARiD
2012 lr2 oil help
Old Apr 15, 2017 | 10:34 PM
Farmskis's Avatar
Default 2012 lr2 oil help
In reading my manual it says 11.9 pints (5.9 quarts) of 5w 30. In researching around I see people say the quantity is more. Does anyone know the oil quantity for the 3.2 six cyl gas? I think my manual is wrong considering the only engine choice it shows is a 4 cyl. Thank you! Any oil recs? I would be willing to hear what you guys run.
Old Apr 16, 2017 | 02:19 PM
LR Techniker's Avatar
The capacity is 7.7 Liters or 8.1 quarts. We use Motul synthetic oil in 5W-30 grade.
Do yourself a favor and pick up a new drain plug washer if your filter doesn't come with one. Most quick lube places don't replace them every oil change. They are "one time use" crush washers.
Old Apr 19, 2017 | 09:16 AM
Farmskis's Avatar
thank you! I will pick up a washer for the plug. I have 5l of liqui moly top tech 4200 5w30 left from my previous vehicle. Do you know if this meets the specs? I would like to use it if it does. If not, I will look at getting some motul.
Old Apr 22, 2017 | 08:19 PM
I'm pretty sure Top Tech 4200 was specifically made for Diesel engines, but will also work fine in gas. Usually, if you are using Liqui Moly, the Leichtlauf is the better choice.
Old Jan 5, 2018 | 07:52 PM
ianplus's Avatar
Hi, do you know what size is the washer as well as the drain plug bolt? I cannot find the size anywhere.
Old Jan 5, 2018 | 08:39 PM
OverRover's Avatar
Have at it
Old Jan 5, 2018 | 09:12 PM
ianplus's Avatar
Thank you!
Have at it
Thank you!
mryan55
Jul 25, 2013 05:09 PM
clark grizwald
LR2
May 24, 2013 04:58 AM
bfriend54
LR2
Apr 19, 2013 08:52 PM
LR2SURGEON
LR2
May 21, 2012 05:35 AM
cl0r0x70
Feb 20, 2011 03:15 PM
