Sponsored by: CARiD
2012 LR4 Infotainment lock up - back up camera, stereo, Nav
Old Feb 3, 2020 | 07:01 PM
krisjmaxwell@gmail.com's Avatar
7th Gear
Default 2012 LR4 Infotainment lock up - back up camera, stereo, Nav
Hi there, hoping someone can help. My LR4 sat in the garage for a week while away, and the infotainment system became inoperative.
Upon starting it up, the audio/video tab was dark grey so you couldn’t click on it. When you click on Nav, it says initializing but doesn’t start, and when in reverse, the screen goes black. I checked all the fuses and they’re all fine.
My local dealer (Langley BC) said: We would have to re-scan the computer – my manager has said it could be 2-3 hours diagnostic including software update attempts.
They charge $165 + tax an hour. Is there a tool I can buy that can fix this?
Thanks!
Old Feb 3, 2020 | 07:19 PM
DakotaTravler's Avatar
Did you try a hard reset?
Old Feb 3, 2020 | 07:24 PM
7th Gear
No, is that easy? Will definitely try.
Well I never thought disconnecting a battery was hard, so yes I would say its easy.
Old Feb 3, 2020 | 07:26 PM
7th Gear
Haha. Amazing. Will try tonight. I have been told my battery is near the end of its life, so will replace too.
Old Feb 3, 2020 | 07:28 PM
That could easily be the problem then, basically the computers experienced poor level low enough to sorta scramble them but not reset them. Disconnecting one lead on the battery for a couple minutes may take care of things.
Old Feb 4, 2020 | 10:17 PM
7th Gear
I disconnected the negative lead for a bit, but no change (as the battery is likely too dead). I did buy a new battery but became a bit intimidated with all the connections. I also couldn’t find a good video online on how to change it. I’ll keep searching/reading. Feel free to share any thoughts. Thanks!
Old Feb 4, 2020 | 10:26 PM
Yeah, if the battery is dead you will not have much luck. Does yours also have a secondary battery?
Old Feb 4, 2020 | 11:10 PM
7th Gear
No. Found a video, swapped the battery, which was easy. Unfortunately it didn’t fix it, but everything else is fine. Think I just have to take it in for a $500 dealer download unfortunately. Car companies shouldn’t be able to charge for that....
Old Feb 5, 2020 | 10:51 AM
Did you check for the secondary battery? I am not sure if its standard on all LR4s, its in the opposite location of the main -across the engine bay. Much smaller battery.
alexNLA
LR4
Apr 2, 2021 12:58 PM
Henry Fraser
LR4
May 5, 2019 03:25 AM
Jonski
LR4
Sep 19, 2018 09:42 AM
weezy
LR4
Jul 4, 2014 01:10 PM
itsallinthemusic
Sep 8, 2011 01:50 PM
