Sponsored by: CARiD
2017 Ranger Rover Hse TD6 diesel
Old Jan 7, 2025 | 01:58 PM
Czer's Avatar
Default 2017 Ranger Rover Hse TD6 diesel
Hello hope all is well,
I received an incorrect DEF pop up on my vehicle I assumed it’s because I used Blue DeF which is not the rated AD blue that Range Rover specifies, so I bought correct DEF and added to vehicle that did not change anything I’m assuming maybe I will need to Drain out, DEF does anyone know if that will fix it or will I have to drain and maybe change or clean def injector or filter. Would anyone know the location and how to remove these things and if so would I need to reset computer and how can I even do that not being a certified dealer/ tech at home, Im bit confusing I know I added alot hope someone can help thanks in advance.
mtaylo32
Apr 6, 2026 10:45 AM
5Xdriver
Apr 27, 2025 09:47 AM
TD6disco
Feb 7, 2024 04:25 PM
JMV
Feb 5, 2024 04:44 PM
Joeyz101
Jan 1, 2024 10:35 AM
