Sponsored by: CARiD
2nd gear grinding
Old Nov 14, 2007 | 04:16 AM
rumpig70's Avatar
Default 2nd gear grinding
hey i hope someone can shed some light on this one for me.
my 93 disco crunches into second gear every time i shift to it,if i`m doing more than 1000 revs up or down shifting it really doesn`t like going into gear,gear boxoil levels are good clutch is good.shifter selection is a bit sloppy but its not missing the gear.
Old Nov 14, 2007 | 07:54 AM
Default RE: 2nd gear grinding
Time for an overhaul. sounds like the syncros are gone along with other possible parts, kind of normal especially if you have used 2nd. gear to slow down.
Old Nov 14, 2007 | 04:55 PM
Adz's Avatar
Adz
'93 Disco with manual gearbox? Which bit of the UK are you in then?
Old Nov 15, 2007 | 02:05 AM
Bartell's Avatar
ORIGINAL: Disco Mike
Disco Mike is right.
Seems that it is always the 2nd or 3rd gear on all versions of the LT77 and LT85 that goes first. Yours is heading south.
If you are in the UK, you don't have to rebuild the box. You can simply exchange it. Use a reputable company..avoid ebay. The world's largest LR gearbox refurbisher is Ashcroft Tranmissions in Luton. They will charge you£395.
If you are planning to keep the vehicle a LONG time, see if you can switch to a post-February-1999 R380 at a reasonable price.
James
Old Nov 15, 2007 | 03:22 AM
rumpig70's Avatar
thanx guys looks like i got some work to do,oh! by the way i`m on the gold coastin australia
thanx for the feedback...
stu44mag
Dec 2, 2010 10:11 AM
adambarry
Mar 30, 2010 08:17 AM
crispy
Dec 30, 2008 08:13 AM
sdsilvere38
Sep 1, 2008 12:08 PM
freeland02
Engine & Internal
Nov 25, 2007 04:44 PM
