Sponsored by: CARiD
4.6 in a d1 noob questions
Old Oct 25, 2015 | 04:50 PM
robertf's Avatar
yes, and on every make of vehicle ever made you reuse that stuff when replacing an engine
blocks are identical except for cps mount, easily transferred over with minimal welding or even jb weld
Old Oct 25, 2015 | 05:44 PM
ihscouts's Avatar
Yep, it's just a short block swap with an adjustment. There are threads on the net about guys swapping in 4.6 blocks into RRC and Discos. Anyways, the 4.6L crank n rods is the way to go, that's about $500. If you can, try to snag an aftermarket cam as well. Just a little more aggressive than stock.
Old Oct 25, 2015 | 06:59 PM
Thatguy's Avatar
has any one put up horse power numbers for the stoker?
Old Oct 25, 2015 | 07:13 PM
ihscouts's Avatar
217 for the standard 4.6. You'd be around that number.
Old Oct 25, 2015 | 07:44 PM
robertf's Avatar
its not just the max hp that matters. across the rpm range is a noticeable improvement over the 4.0 and 3.9
thats with the 229 cam, dont waste your time with the stock 4.6 cam
Old Oct 25, 2015 | 07:50 PM
ihscouts's Avatar
There's also a noticeable vibration with the 4.6 that isn't there with the smooth 4.0........ gain some, loose some.
Old Oct 25, 2015 | 08:37 PM
robertf's Avatar
havent noticed it in either of my 4.6 d1s
Old Oct 26, 2015 | 08:58 PM
Thatguy's Avatar
so the consensus is any 4.6 crank and rods, keep the 4.0 flat top pistons and that the crower cam is worth the money? sound right
Old Oct 26, 2015 | 09:05 PM
ihscouts's Avatar
Sounds like BINGO! That should keep you within your budget. Which Crower cam you thinking of?
Old Oct 26, 2015 | 09:09 PM
ihscouts's Avatar
Also, forgot to mention it but a set of lifters would do the cam right....... you probably knew that though...... That would push you over your budget. I believe the Buick 215/300 also fit the lifter bores, might be a wee bit cheaper. Double check the size cuz I'm not "feeling it" today. Been a long one....... wiped out and it's only Monday.
