5 volts to fuel pump - need help
1997 Disco - had the no fuel stall and coast the other day and read on here not to assume the pump and read power - read both plugs - red was 5 volts and black was a full 12 volts. I replaced the multifunction fuel pump relay under the hood on the passenger wheel well - same result. What else should I be looking for before considering a new harness? Thanks for the advice !
Jeremy
Jeremy
Thanks for the info - I will pull the pump to check function. I have been relying on Haynes manual that I have found to be not so accurate or detailed. I also have a '94 Disco that needs some TLC, any suggestions on which manual is worth its weight in parts tried that I should buy? Thanks again -
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
