Sponsored by: CARiD
5 volts to fuel pump - need help
Old Aug 4, 2008 | 07:13 PM
Someszy's Avatar
Default 5 volts to fuel pump - need help
1997 Disco - had the no fuel stall and coast the other day and read on here not to assume the pump and read power - read both plugs - red was 5 volts and black was a full 12 volts. I replaced the multifunction fuel pump relay under the hood on the passenger wheel well - same result. What else should I be looking for before considering a new harness? Thanks for the advice !
Jeremy
Old Aug 4, 2008 | 09:49 PM
roverguy7's Avatar
Default RE: 5 volts to fuel pump - need help
you should be looking for your problem... wiring is good, the 5v is for your fuel tank press sensor, leave it alone, if you have ground to the pump and still no fuel, you need a pump
Old Aug 5, 2008 | 08:45 AM
Someszy's Avatar
Thanks for the info - I will pull the pump to check function. I have been relying on Haynes manual that I have found to be not so accurate or detailed. I also have a '94 Disco that needs some TLC, any suggestions on which manual is worth its weight in parts tried that I should buy? Thanks again -
Travelor
Sep 24, 2015 06:11 PM
jh.
Aug 12, 2013 08:20 PM
Aaron Sandland
Jan 11, 2013 11:17 AM
wheelgarage
Dec 27, 2011 03:05 PM
JumPeR04
Apr 7, 2011 09:52 PM
