Sponsored by: CARiD
94 Disco I starving for fuel going uphill
Old Mar 24, 2008 | 10:58 PM
oldscoutII's Avatar
Default 94 Disco I starving for fuel going uphill
I need help with this one. A 1994 Disco I straight drive is starving for fuel when it is driven up an incline. Once level, or facing downhill it runs fine.
When it is on an incline it will idle but will not accelerate. I can "pedal" the gas pedal and get it to creep up the hill but it will not accelerate.
Anyone have any suggestions on the problem and cure?
Thanks!
Maurice
PS - I just purchased this vehicle and the prior owner gave me the paperwork about a recall for gas tank replacement. Does the recall and this problem have anything in common?
Old Mar 25, 2008 | 08:54 AM
Default RE: 94 Disco I starving for fuel going uphill
I would suggest you replace the fuel filter first, if it still continues then have your fuel pressure tested, if low buy a new pump and go in for your recall, ask the dealer to install your new pump when replacing the fuel tank, they will probably charge you a little but it will be worth it.
MrTortoise
Sep 29, 2017 02:37 PM
Lord Wert
Apr 12, 2013 10:44 AM
ryann
Nov 20, 2011 03:34 PM
sabata
Sep 22, 2011 08:38 PM
pman
Sep 19, 2006 04:04 PM
