95 D1 vibrating
so your driveshaft joints are tight. you don't have axle shaft u joints, but you could have bad/loose wheel bearings. swap the tires front to back and see if it helps. is the truck lifted? you have a 95 so you still have the rear rotoflex thing... hows that look? with a lift that will wear or show wear faster than normal.
