Sponsored by: CARiD
97 Disco 4.0 V8 not starting.
Old Mar 26, 2013 | 07:21 PM
misterme's Avatar
8th Gear
Default 97 Disco 4.0 V8 not starting.
I have a 97 Disco 4.0 V8 that's cranking but not starting. I've scanned it and got the following codes:
P0102
P1187
P0300
P0306
P1314
P1313
I'm guessing misfiring is why its not starting. I don't know what I should be checking to find out what's causing the misfiring. Help.
Old Mar 26, 2013 | 07:47 PM
Mis fires are caused by worn out spark plugs and wires.
So start with a tune up.
I assume you have checked the fuel pressure and have checked for spark?
Old Mar 26, 2013 | 08:14 PM
misterme's Avatar
8th Gear
Yes, I've checked fuel pressure and for spark. I changed the spark plugs and wires last spring. I didn't think they would go bad that quickly. I'll check the plugs and wires anyway.
Old Mar 26, 2013 | 08:35 PM
If you used cheap plug wires you are lucky they lasted a year.
These trucks eat plug wires for lunch, you have to use good ones, Magnecore, STI, Kingsbourne seem to work best and hold up the longest,
Old Mar 27, 2013 | 01:41 AM
The P0102 can indicate that MAF sensor is not plugged in, etc. Be sure it is seated firmly.
Old Mar 27, 2013 | 09:42 PM
misterme's Avatar
8th Gear
Got it running with new plugs. Cleaned the MAF sensor clips with contact cleaner. All codes are gone.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
primecooler
May 5, 2009 03:53 AM
dragon_avaloch
Nov 15, 2008 07:35 AM
pants
Oct 19, 2005 12:47 AM
