Sponsored by: CARiD
97 Disco Charging system
Old Jan 11, 2008 | 08:14 PM
maddash6's Avatar
3rd Gear
Default 97 Disco Charging system
My alternaror went out on my 97 Disco so I replaced it but I am still having issues keeping the battery charged. I have had the new alternator tested and it is good. The strangest thing is that when the battery is losing it's charge my battery light does not come on instead I get the SRS light, the speedometer will fluctuate as well as the tac.(If the tac is working) Any ideas on what I should look for.
Old Jan 12, 2008 | 07:38 AM
Default RE: 97 Disco Charging system
The SLS light is on because of a low voltage issue, your speed-o and tack are voltage and alternators issues.
Who and how was the alternator tested?
Old Jan 12, 2008 | 11:44 AM
maddash6's Avatar
3rd Gear
I had it tested at Auto Zone. We tested it with nothing on and under load and both time it read 14.
Old Jan 12, 2008 | 03:10 PM
maddash6's Avatar
3rd Gear
Figured it out. The problem is in the switch for the heater. When the heater is on it drops the charge below 10 volts. With out it it stays at 14.
Thanks Mike for the reply.
Old Jan 13, 2008 | 08:12 AM
Doesn't make since, and will be curious to see how it turns out with a new switch.
Marsalad
Nov 21, 2012 10:11 AM
nahtanoj
Feb 9, 2011 08:02 PM
christians1600
Jun 19, 2009 03:35 AM
charley_bucket
Apr 29, 2009 03:58 PM
sabsr1954
Oct 24, 2006 04:25 PM
