Sponsored by: CARiD
97 discovery cv/swivel
Old Nov 3, 2023 | 02:57 PM
Tuck32's Avatar
4wd High
Default 97 discovery cv/swivel
Gokd day all. Question regarding CV and Swivel. Are they one and the same grease point? Thanks
Old Nov 4, 2023 | 02:04 PM
Harvlr's Avatar
Hi Tuck. Post your technical questions in the Disco 1 section of this forum.
Old Nov 7, 2023 | 03:23 PM
WaltNYC's Avatar
the CV joint is housed inside the solid swivel ball. That ball is filled with swivel ball grease (I have found Tractor Supply '00' grease to be the same and much cheaper).
Old Nov 7, 2023 | 06:45 PM
nathanb's Avatar
The Proline grease from RN is not as badly overpriced as Land Rover's own. AB also has Britpart and All Makes grease tubes for about $10/swivel. It is indeed the same as any CV grease -- a mixture of grease and gear oil. The axle has seals that separate the differential and axle housing from the CV joints. If those seals leak, you'll get gear oil in the CV's anyway -- and that's fine. They used to be like that and Land Rover only changed it because the swivel ball seals would leak the oil out. They found that oil thickened with a lithium grease would not leak as much and they could even cut out chrome-plating the swivel *****. They also did away with the swivel drain plugs.
This question and answer pertain to 1st generations of Range Rover, Defenders, and Discovery.
Old Nov 18, 2023 | 11:23 AM
danyjames_9's Avatar
Banned
jimvw57
Apr 29, 2015 02:17 PM
stephenspann27
Feb 12, 2015 07:39 PM
paulthepipe
Sep 8, 2012 12:35 AM
coldstart
Feb 21, 2012 06:42 PM
handsome rob
May 22, 2009 07:22 PM
