Sponsored by: CARiD
97 LRRR 4.0 SE - Radio Fuse Location
Old Dec 14, 2008 | 09:44 PM
vjm530's Avatar
Default 97 LRRR 4.0 SE - Radio Fuse Location
I have a 97 Land Rover Range Rover 4.0 SE and my radio just died. It was suggested to pull the radio and replace the 'rear' fuse. I removed the radio but cannot find the fuse mentioned. I checked the fuse under the passenger seat and it looks ok but now I realize that I will have to re-enter the 'code' since I pulled the fuse which I don't have. Is there a way to find/retrieve the code w/o going to the dealer? The screen lites up but no info (blank) and also my flashing red theft warning lite is not on any longer either.
Any help in locating the 'fuse' and any other assistance would be greatfully appreciated.
Thanks in advance.
Old Dec 16, 2008 | 05:50 PM
vjm530's Avatar
Default RE: 97 LRRR 4.0 SE - Radio Fuse Location
UPDATE: Located rear fuse but it is ok. Got radio code from dealer. He suggested that I disconnect the neg terminal of the battery for a few minutes, reconnect and then enter code.
RESULTS: Disconnected, reconnected, turned on radio to enter code but screen lites up and is blank. Reset windows, etc. No 'Code In' message. When I press the 'On' switch and the 'BND" button at the same time I can get the radio or CD player to work then shuts off after 2-3 minutes. Also, when radio is on there is a beep every second or two. Since the screen is blank there is no indication of when to enter the code. And, the red theft flashing light does not come on.
CONCLUSION: It seems that the radio needs to be reset so that the code digits can be entered and make the unit functional again.
With all this said, does anyone have any idea how I can enter the Code sequence? Even though I had the battery disconnected I'm trying the suggested manual method of leaving the radio on (lit) for an hour or so in case I accidently entered the wrong sequence at some point. I hope this will eventually turn on the 'Code In' message so I can proceed.
Any help/suggestion would be greatly appreciated.
Thanks in advance.
NicoleRover
Jan 7, 2015 03:08 PM
vjm530
Mar 1, 2013 03:49 PM
vjm530
Oct 15, 2011 09:51 AM
vjm530
Nov 18, 2008 05:49 PM
Roveroh
Aug 7, 2008 09:42 AM
