Sponsored by: CARiD
97 Range Rover
Old Sep 19, 2010 | 12:50 AM
gingerbakr's Avatar
Default 97 Range Rover
Hello, I'm new here and need some help, my rover's ac works great, but the ac fans do not work, I have the book diplay on my climate control, the fan speed switch will not work so it blows on high all the time, and the display that shows the the fan speed high to low is blank, all the other funtions work great, could this be a blown bulb, could the ac fans be a switch, I just put in a new fuse box and new relays and checked all fuses all are good, this one has me confused, any help would be great,
Thanks mike
Old Sep 19, 2010 | 11:17 AM
Rovin4life's Avatar
the fans themselves using cause the relays to start melting cause they stay on. You need usually two fans one on each side. Its the internal relay inside the fan that go bad.
Old Sep 19, 2010 | 02:10 PM
gingerbakr's Avatar
Thank you, I will check power to the fans,is there a way to jump the relays to see if they work ?, Thanks, Mike
Lincoln Tarantino
Nov 14, 2011 10:41 PM
Skimino Farms
Jul 30, 2011 07:47 AM
wilson96rr
Jan 3, 2009 10:44 AM
nextelsucks
Appearance & Camping Set Ups
May 18, 2008 08:58 PM
nextelsucks
Mar 28, 2008 09:25 PM
