ABS failure Traction failure
I am about at the end of the road here. I have a continual "ABS failure" "Traction Failure" message. I have been to British car service more time that I care to think to resolve this. No fault is logged in the computer. The wheel sensors have been checked and the accumulator has been replaced. The EAS compute has been replaced, because I had a problem with the EAS that was thought to be connected. That cured the problem for about a week, and it is now back. Any ideas other than selling the thing?
Wayne
Wayne
What was the outcome with your problem? There ought to be some indication of the cause on the scanner. Try getting a different diagnosis, contact bonnettoboot@earthlink.net in Los Angeles I know they have the Equipment.
THEY EXPLAIN stripping back the yellow and green wire and running to power and
Grounding the other wire under the
Modulator where all the plastic lines
Run.
nazdackster
Jun 2, 2009 09:20 AM
wizardmagu
Apr 23, 2009 01:38 PM
thelokolobo
Mar 10, 2009 05:34 PM
rodrick smith
Apr 13, 2007 06:09 PM
