Sponsored by: CARiD
ABS/Traction Control/SRS Lights 2004 Land Rover Discover HSE
Old Apr 14, 2015 | 06:40 AM
ugottatri's Avatar
Default ABS/Traction Control/SRS Lights 2004 Land Rover Discover HSE
Intermittently my ABS/Traction Control/SRS Lights will come on while I'm driving. The warning beeps also sound when this happens as well. They will stay lit as long as I drive but all I have to do to get rid of them is turn the car off for a minute or two and they re-set. Sometimes I'll drive it all day and it won't happen again, sometimes it will happen as soon as I re-start the engine. Random as is EVERYTHING problem with a Land Rover but just wondering if anyone can shed some light on this for me.
I also have the problem with the left side speakers cutting out while I'm driving and all I have to do is shift the car from drive to neutral and the speakers come back on again. Not sure if these two problems are related but any help would be greatly appreciated.
Old Apr 14, 2015 | 08:18 AM
Probably a loose wire under the console for the speakers. Search "amigos" there are tons of threads on how to figure out the 3 warning lamps coming on
Old Apr 16, 2015 | 03:25 PM
justryan's Avatar
if a speed sensor is bad you can get the ABS (Anti-lock Braking System ) light coming on ( Relating to Brakes ),
the SRS( Supplement Restraint System )light concerns the Airbags ....
and the Traction control is another light ....
you need get a diagnostic check to find out the faults ..
Old Apr 17, 2015 | 05:55 AM
drowssap's Avatar
run a search for the three amigos, any one of thirty things can set them off.
you need to have your ABS code read otherwise you are just throwing money away.
shuttle valve most like but you have to have the codes or it a expensive guess.
gamecockdisco
Jul 12, 2010 08:34 AM
gsgtsg
Dec 3, 2008 08:41 PM
dsmtrain
Jul 12, 2008 07:15 AM
rodrick smith
Apr 13, 2007 06:09 PM
