Sponsored by: CARiD
Ace
Old Nov 4, 2009 | 03:53 PM
CampCobb's Avatar
Default Ace
I have a 2000 LR DII 91k miles with ACE. The ACE is making whinning noises so I understand it may be going out. I do not want to put much $ into a 91k mile Rover so the cheapest thing would be to buy a regular belt for a DII without ACE and install it so I could do without it. Besides handling, what if any problems should I expect by doing this. thanks.
Old Nov 7, 2009 | 08:51 AM
You should have never purchased a Disco if you weren't wanting to maintain it.
The ACE was a $1700 option, why would you want to disable it, when you could service it and cut the noise some????????????????????????????????????????????
Old Nov 8, 2009 | 08:38 AM
CampCobb's Avatar
One more ? mark and maybe I would understand but I would'nt expect anything less bitter from you Mike, thanks for your help. Cutting SOME of the noise is not an option for me, I want the noise gone. thank you.
Old Nov 8, 2009 | 09:30 AM
Doubtful you will get rid of your noise. I have seen where after throwing many parts and a pump at some ACE units, they will continue to have some noise.
For me, a little noise is worth while for the advantage of driving with ACE.
Old Nov 8, 2009 | 05:26 PM
CampCobb's Avatar
Sorry if I got a little rude but I just don't know how much noise is normal. My ACE may not have any problems. Should I here it inside the vehicle with the windows up? I don't have to talk louder or anything but I can here it quite well inside with windows up. I have flushed the fluid very well with no difference in sound. The ACE is quite the option. My goodness this thing handles unbelievable on interstate turns at +80mph but this noise just needs to subside. Thanks man.
Old Nov 16, 2009 | 12:17 AM
firrhud's Avatar
I accept with information: The ACE was a $1700 option and you don't to disable it.
Old Nov 16, 2009 | 09:23 AM
What fluid did you use? You might consider using a 1/2 bottle of Lucas p/s additive, quite often this will help.
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
Charlie L
Mar 13, 2005 10:14 PM
