Sponsored by: CARiD
ACE Pump temp bypass
Old Mar 16, 2012 | 08:14 PM
Oops, 29 has some other modules on it, so it has to go back. Relay 15 is the ACE relay, on the fuse layout it says the fuse is 14, on the schematic drawing it says 15. Just pull relay.
Old Mar 16, 2012 | 08:17 PM
jayg's Avatar
so pull 14 and 15 from under the dash? or...? dam fuses! lol
Old Mar 16, 2012 | 08:19 PM
jayg's Avatar
i would download the manual but im at a hotel on my blackberry! thanks once again
Old Mar 16, 2012 | 08:53 PM
Don't pull any fuse, just pull relay. If you like, go to hotel "business traveler center", use a real PC, and hit the on-line manual in my signature, not the RAVE. In this case, the schematic page shows fuse 15, and the fuse list page shows fuse 14. But relay does all you should need. And those 14 or 15 fuses are under hood.
Old Mar 16, 2012 | 08:57 PM
jayg's Avatar
so the relay is under the hood? is it numbered, sorry to ask dumb questions but these rovers are new to me
Old Mar 16, 2012 | 09:03 PM
Under the hood on passenger side. Relay 14 should be in the corner, no other relay is physically in the precise corner. Believe cover will be marked. Pages attached, don't know if your crackberry will show up a pdf.
File Type: pdf
Old Mar 16, 2012 | 09:45 PM
jayg's Avatar
thanks bud! im leaving early tomorow morning only have to drive it a few hundred km then ill have the time to go through the manual and figures things out!
Old Mar 17, 2012 | 03:36 PM
jayg's Avatar
thanksfor all the help, i made it home without issues, used a few quarts of power steering fluid and thing went well, my wifes car had a nice film from the constant spray but it cleaned up ok, there are a few things wronf with the truck but no overheating or oil leaks
Old Mar 17, 2012 | 03:42 PM
Might want to re-wash SWMBO's ride with Dawn dishwashing soap.....
Tin_Man
Apr 12, 2014 11:12 AM
jayg
Mar 17, 2012 04:25 PM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
