Sponsored by: CARiD
Adjust kickdown canle for bigger tires ??
Old Mar 15, 2018 | 05:44 PM
ROB99DISCOSD's Avatar
Default Adjust kickdown cable for bigger tires ??
I’ve been bouncing this around in my head but can’t settle on an answer.
If you put bigger than stock tires, or smaller I guess as well, on your vehicle, do you have to adjust your kickdown cable? Meaning my D1’s points are spot on with Rave specs, which are identified by speed ranges. If I’m running my bigger tires my speedo is overstating my real speed but I’m shifting at correct points for stock tires.
Is only the speedo inaccurate? Do I need to get paced and find the incorrect speedo to actual speed differences and adjust the cable to these points? I’m confused....
philwarner
Mar 30, 2017 11:16 AM
Eurobahn LandRover
Other
Mar 16, 2016 08:27 AM
Pikulone
Dec 20, 2014 01:27 PM
raro88
Jul 11, 2014 10:19 AM
ajnolin
Nov 24, 2013 09:29 PM
